Applying thickness?
Applying thickness?
deangelisron
Applying thickness?
deangelisron
Fusion 2.0.19983 arm64 [Native]
MacOS Sonoma 14.61
Stopped using FreeCad, so in the process of learning Fusion 360.
Trying to apply thickness.  My model is a sketch, extruded.  Does this only applies to a solid and not sketches?
questions that i want to apply:
1. apply 2mm thickness. Keeping all sides solid
2. same as 1. above, but includes the bottom face.
davebYYPCU
1.  Try using Modify > Shell, set wall thickness to 2 mm.
2.  select the body to Shell from Browser list, and it will not remove any faces in the function.
Might help….
g-andresen
shell options
günther
deangelisron
@g-andresen Wow, that was easy.  Got to look at all the menus and absorb each function.  I need to add more to this model;
1. rails on each side
2. dove tail  on the bottom
3. a lid to slide into dove tail.   The lid will have circuit board.
4. another component the body to slide into for adjustment.
so I'm sure will have more questions.
lots to learn .... thankx very much and pictures/videos much better than words!!
