Apply multiple joints to objects
rapiddsol
Message 1 of 18
rapiddsol
I am hoping someone can direct me to a resource that can show me the best way to apply joints for this specific application.
Seen screencast. I simply would like to put the bolt in the hole and place the underside of the head on the bracket.
First to admit I don't get these types of joints. Any guidance is appreciated. Thanks for your time.
http://autode.sk/2vmESMV
Replies (17)
Message 2 of 18
TrippyLighting
Is there any reason a simple rigid joint would not work ? What you are describing is not a speciffically special case.
Message 3 of 18
Tutorials to learn about assemblies and joints are available on youtube and autodesk websites.
For example you can try this video.
Take a look at this screencast to get a basic idea of applying joints between two components.
Message 4 of 18
rapiddsol
Thanks for the reply Mandy.
I have sat through that tutorial and unfortunately it does not address my specific issue.
I appreciate your screen cast also, but the situation I displayed is a bit different.
The hole I am trying to mate with the screw is separated by a bracket with a slot in it.
So the bolt body needs to be mated with the hole (concentric) and the underside of the bolt head mated to the top of the bracket (planer) with the slot in it.
I realize I can make the concentric joint and off-set the bolt the thickness of the bracket, I also know I can create a joint origin where I need it...but I shouldn't have to... I believe there should be a better way.
I tried making a concentric joint in one step, then a planer joint in another but they conflicted.
Thanks again for the effort.
Message 5 of 18
TrippyLighting
You could create a cylindrical or slider joint between the bolt and the hole in the bottom part and then a slider joint to planar joint between the underside of the bolt and the bracket.
IF that does not work, your assembly has geometric problems.
In a mechanical design such as this I'd only go through that effort in very special circumstance. Adding joints with degrees for freedom is only going to put unnecessary burden on any system having to evaluate such a joint.  A rigid joint with a offset is all I'd do.
Message 6 of 18
Sorry that I misunderstood the question.
As you already mentioned, the easiest solution for this is creating a rigid joint between hole and bolt and offsetting it by slot thickness.
But if you don't like to do that then you can try this.
As shown in the screen cast if you have the sketch for the slot you made, you can get a joint origin at the center.
But if you don't have the sketch of the slot it is always better to just create a joint origin
Message 7 of 18
rapiddsol
Thanks Mandy,
 As you stated the "easiest" solution was for me to create a joint origin. I used between two faces and the top surface of the bracket, then had to adjust the axis (direction the origin was facing).
Seems crazy the "easiest" solution requires the fabrication of an origin, or creating rigid joints with multiple dialogue boxes. what are the chances the joint origin is parametric and will update if I change the thickness of the material....hope I don't have to find out.
Thanks again.
Message 8 of 18
How robust is the approach of offsetting by the flange thickness to changes in that thickness. Surely if there is a way to mate to  a face (which I can't find in 360 because it insists on using snap points) that is much more robust to changes in geometry of the other parts?
Message 9 of 18
ritste20
If you tie the flange thickness to a parameter and use the parameter as your offset distance in a rigid joint, I would consider it very robust to changes.
If you increase the thickness too much you will run out thread engagement but the model won't break.
side note - you have to use the snap points to locate the joint origin but you can use a planar joint between two faces regardless of the snap points you select.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 10 of 18
Yep ok get that.
Is it not possible at all in Fusion 360 to do the two degrees of freedom with seperate mates?
In this case would be a mating the bolt to the hole and then a separate mate to from face of bolt to face of flange...
PS can 360 mate faces? or do you have to use the somewhat arbitrary seeming snap points?
Message 11 of 18
TrippyLighting
You could use a slider or cylindrical joint between the bolt and the thread and then a planar joint between the underside of the bolt and the upper face of the bracket.
Message 12 of 18
TrippyLighting
Not separate geometric mates as Fusion 360 does not use the concept of mates.
But as described in my last post, you can use 2 separate joints. Not sure I would recommend using that technique very frequently in a single design but for occasional use it should be fine.
Message 13 of 18
Ok I think I'm getting there.
Last Q is on Planar joints.
I would expect it to only constrain motion in one Axes. However it only gives you the ability to slide in a single axes.
That, almost by definition is not planar. Is there a way to achieve true planar?
Message 14 of 18
TrippyLighting
It would probably be helpful if you share your design or a screencast of what you are seeing. What you describe ids not the default behavior of a planar joint.
Message 15 of 18
This dialogue for a planar joint only allows you to specify a single axis it can slide in as far as I can see?
Message 16 of 18
TrippyLighting
Click OK and then see how the joint behaves.
Message 17 of 18
chrisplyler
You could do:
1. Pin-slot Joint between bolt and slotted bracket, such that the bracket face was up against the back of the bolt head.
2. Cylindrical Joint between bolt shaft and hole, such that the bolt is lined up with the hole but free to move in/out.
3. Planer between back face of slotted bracket and the face with the hole.
This would pull everything into place, and would adjust properly with changes to thickness of the slotted bracket.
Message 18 of 18
ritste20
That is a bit of a misnomer. Planar joints act as you would expect a mate or flush constraint from inventor or solidworks.
UNLESS you have other joints that would create conflicts with the additional degrees of freedom.
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
