Appearance not duplicated correctly in rectangular pattern repeats.
TitaniumBlue
Message 1 of 1
TitaniumBlue
I am creating a 3D model of a specific woven texture.
My intention is to render the model, and use the image to map on my box.
The problem I have is that I modified a 3D oak texture from the Fusion library.
I made some tweaks, so that I could get the desired effect for the stands of the woven material.
Then I proceeded to create a rectangular pattern of my weave. Repeat the basic tile I created.
The bottom horizontal array duplicated the appearance correctly.
But the vertical array looks like it is using the appearance first created. The one before it got tweaked to get the look I want.
As I prepared the link to the file, I can confirm that I see the difference between the top arrays in the Fusion web viewer. Here:
http://a360.co/2uknlQ6
My plan is this:
I will save the tweaked appearance material in my favorite and try reassign all the same...
Thanks for any help in resolving this.
Replies (0)
