Anyone know how to fix this error?
FacebookGroupMember
Message 1 of 9
FacebookGroupMember
Replies (8)
Message 2 of 9
FacebookGroupMember
Did you project a line from some other component/body that isn’t in the project anymore?
Message 3 of 9
FacebookGroupMember
Jim Vogel that is likely.
I had to delete a bunch of stuff and redo it.
Message 4 of 9
FacebookGroupMember
Jim Vogel if I delete this component, which is early in the timeline, will I loose everything after it?
Or can I just redo this sketch/extrud? That’s all this component is, a simple sketch, followed by an extrud.
Message 5 of 9
FacebookGroupMember
Don Bower I had a similar thing happened to me. I just re-drew the sketch, redid the extrusion, and then had to Reconnect the projections in the other sketch.
Message 6 of 9
FacebookGroupMember
Jim Vogel I’ll give that a throw...
Message 7 of 9
g-andresen
Please share the file and say which sketch (feature) it is about..
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 8 of 9
shahriarsifat1802164
I think you have deleted one of your main sketches. Go to your main sketch and redraw it or undo your progress. give the necessary dimensions.
Thank you
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 9 of 9
FacebookGroupMember
I did some repairs, and the error condition is gone now.
Thanks to everyone!
