Any way to hide Control Point Spline Handles
matthewrjacobs
matthewrjacobs
@jeff_strater / @TrippyLighting ,   do you guys know of  a way to hide the control point spline handles (hulls) once the sketch is finished.  See attached pic.
TheCADWhisperer
If they are visually disturbing - you could start a New Sketch - Project the splines and then turn off the visibility of the parent sketch.
jeff_strater
no, there is no way to hide just the control polygon for a CV spline.
Jeff Strater
Engineering Director
matthewrjacobs
@TheCADWhisperer - Thanks for the workaround,  I'll try it out.
@jeff_strater -  Could you please add the ability to show/hide the control frame to the pile of requests,  it is rather distracting.
UprightApe
Agree - Love the control point splines, but should have a hide option just like for points - perhaps the 'hide points' checkbox in the panel should also hide the control point frame.  Just too noisy.
johnwcarew
Observer
Observer
There must be a way to hide them. If you import a SVG, all of the control frames are hidden and you must select each and unhide them.
