Hi Fellows,
Cookies and CADmen are the best friends, aren’t they?
They also give a tremendous service elevating CADmen alertness, innovativeness and passion for a new design. Chew Chew To Them!
As evidenced by responses to this thread, they also entertain and educate us. Chew Chew To Them!
… so let’s cut some more …
The below cookies cutting utensil has been designed based on a raw mathematical formula describing the curve of a circle-roller cutter.
θ = r/R * sin( t )
x = R*cos(θ)
y = r*cos(t)
z = R*sin(θ)
where t∈{0,2*π}, r-cookie radius, R-roller radius
The file CookiesCutterCurve containing the respective sketch/curves is attached.
Parameters used are: {r,R} = {10,20/3},{11,22/3}
Serve yourself if you want to bake your own cookie in a CADstyle.
Curves file:
CookiesCutterCurve https://a360.co/39YQI0h
4K video files (for private non-commercial use only😞
CookiesCutter_mono https://a360.co/2RacKor size: 20 MB
CookiesCutter_stereo https://a360.co/2tTHvWv size: 65 MB (red/cyan anaglyph glasses required)
Chew Chew To Them!
MichaelT
PS.
Caution!!! Be aware of both side and bottom effects…
MichaelT
