- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
I have read a few other posts regarding creation of a tolerance between parts created using Combine/Cut, but the options do not work in this case.  At least by my greenhorn status.  I have created the spline shaft and base as shown in the attached screenshot.  The pieces are eventually going to be 3d printed so some clearance is a must.  I have printed the spline shaft, and several bases using a couple of things to get them to fit.  First was scaling which was a total bust because scaling alters some of the dimensions preventing the pieces from fitting at all.  Specifically, the inside wall of the splines in the base become too large. The holes in the corners would also be out of place, and wrong size.  I also tried creating an offset around the inner diameter of the splines, but that also fails because of the 45 degree taper in the sides about 1/2 way down.  So is there anything else to try other than re-designing the base and designing in the clearances in the dimensions?
Wayne
