Animations
Animations
MatthewECornelius
Animations
MatthewECornelius
I have been having issues with the Animations workspace being extremely buggy. I cannot show the file I am working on due to the content being classified. Everything from not being able to even type numbers into the boxes, not being able to move or select items in the timeline, you name it. Literally that whole section of Fusion is not working on my laptop. Anyone else experiencing this?
Apple M1 Max
64GB
Sonoma 14.2.1
samuel.templeUCPAE
Hello @MatthewECornelius
Are you still having issues with the Animation workspace?
If so, would you be able to attach a screen recording to show the behaviour? As this will help greatly in investigating possible reasons for the buggy behaviour.
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
MatthewECornelius
Sorry for the late reply and not getting back to you. I have decided to attach the file i am trying to get to work in the animation work space. When you play back the animation you can see the needles moving on the gauge correctly for the y axis travel, then when it goes to "probe" the x axis you can see the needles fly off. I cannot get it to work correctly.
I also have several other animations I would like to make to show the other probing methods of the haimer, that's why the part looks the way it does. It would be fantastic if this could work as it would make things way easier to explain having the animations available.
Matt
samuel.templeUCPAE
Thank you very much for getting back to me and for sharing your model, it has been incredibly helpful.
Now that i have been able to reproduce the bug and my development team will investigate this matter further.
Thank you again for your help and for your patience.
Ticket - FUS-153708
Samuel Temple
samuel.templeUCPAE
After some more looking into this issue i have realised that this isn't a bug. What has happened is that the pivot point was not correctly set. I have added a screen recording to show you how to change it.
BeforeBeforeAfterAfter
Samuel Temple
