Animation pivot point
gordonclamp
gordonclamp
I wish to move the pivot point in Animation. The facility exists in the "Transform Components" dialog box, but when you re-position the pivot the component you are trying to move stay's put, although a move angle is indicated.
I am trying to animate the opening and closing of a carton from a flat blank so need the panels to rotate around the crease lines (panels are individually modeled components and do rotate in the model). At the moment the pivot and move points show in a random position on each panel.
Phil.E
It sounds like you aren't clicking to accept the new pivot.
Here are the steps in image form. Please let me know if this helps.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
gordonclamp
Cheers that has made life simple
THANKS A TON , THAT HELPED A LOT!
c.antoniosf
Observer
Observer
not sure if its due to the update, but this is no longer works
laughingcreek
still works for me.  can you screen cast what your doing that's not working?
