Animation: camera option "perspective"
2 REPLIES 2
tommy_koehlerX3Z7W
162 Views, 2 Replies
Is there any way to create an animation in perspective view?
Searching for that problem only brings up this site:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Camera-view-switch...
...which, if i understand it right, first says that the problem can be fixed by creating a new storybook, and one sentence later states that perspective view only exists in design workspace.
If there is no way to set up perspective view in animation, this is a feature customers really would like to see being implemented in Fusion...
2 REPLIES 2
When you set perspective it records perspective, if you switch ortho it records ortho.
Thank you!
Meaning, the work around is to go back to design workspace, switch to perspective, go to animation workspace, create new storybook.
Only thing missing is the "Camera Options" within animation workspace to make clear how to use it...
Technology Administrators
