Angular Plane glitch
Markclayto
Markclayto
When inserting an angular Plane after selecting the angle then finishing the operation the plane switches to the negative value.
Its not a big problem as all i do is set the plane to the opposite direction i need then on close it reverses and i get the right outcome.
See Screencast Kind Regards Mark
innovatenate
Autodesk Support
Autodesk Support
Could you share a public link to this design file? I did some simple, quick testing, but I did not have any luck reproducing this issue.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Thanks!
Nathan Chandler
Principal Specialist
