Am not able to apply a joint to two components
jmwallach51
Message 1 of 9
jmwallach51
I have used Fusion for about a year now.  Currently I am using my personal copy (I am on subscription) at the company i work for to CNC program mills to make prototypes.  I am trying to design an assembly but I can not put a joint (cylinderical) between two components.  Every time I try, I successfully define the joint only to have it fail when I exit the feature definition.   I get the message to the effect:  Model geometry lost, using cache to build feature.  Redefine feature references.  Which I do, trying every possible surface in both parts numerous times only to get the identical message showing a red cylinder near the model.
Unfortunately I can not, show the model but can show a partial that has the Joint relationship.
How do you make a proper Joint relationship?
Replies (8)
Message 2 of 9
lichtzeichenanlage
The image is 400 x 280 pixels. Hard to see anything. Can you please provide full screen screen captures or better a screen cast or best can you share the project?
Message 3 of 9
etfrench
You probably need to fix the errors in your timeline.
ETFrench
Message 4 of 9
jmwallach51
I'd love to share but this is intellectual property  the part you see is the joint location and will work exactly as I need.   Please see the larger attached image
Message 5 of 9
etfrench
Does it still fail when you copy those two components to a new file?
ETFrench
Message 6 of 9
TrippyLighting
Most of the people on the forum including myself provide the help here on a voluntary basis.
The 2 parts you show in your screen shots look very simple. As such I don't think it is too much to ask for that you simply re-model these 2 components in a separate file that re-produce the behavior you are seeing.
Message 7 of 9
jmwallach51
I am only showing the parts of the model that have the joint as this is a proprietary design and I can not show the whole model.  Yes I can remodel the design but that is a lot of work  and if the model is not recoverable, shouldn't Autodesk  want to understand why this happened.
I tried clearing the cache but this doesn't help.  I also tried rebuilding the failed features but that doesn't help either as this happens no matter which feature I try to use.  The suggestion to copy the model to another file might work but how do you copy the model to another file?
Message 8 of 9
lichtzeichenanlage
Right-click the component and choose Save Copy As
Message 9 of 9
jmwallach51
This works!!  thank you.  When I saved the component from inside the assembly to a new file and then inserted this model into the assembly I can now define Joints
