Am I missing a simple way to draft a circular surface?
Message 1 of 8
I have a body that's made of two coaxial cylinders, sharing the same base - a short, wide one and a thin, tall one.
I want to draft (?) the visible part of the top of the short cylinder so it's at an angle, not perpendicular, to the side of the tall cylinder. It would be similar to adding a short cone (of the same radius) on top of the short cylinder.
I can think of a way to do this by lofting, but maybe there's a more straight-forward way?
Replies (7)
Message 2 of 8
TheCADWhisperer
Revolve.
Message 3 of 8
Here's the f3d. The body is called 'Roller outer'
Message 4 of 8
Cave_Master
Have you tried a revolve?
Message 5 of 8
Cave_Master
Chamfer?
Message 6 of 8
TheCADWhisperer
See Attached.
I took it all the way to the edge, but of course you could shorten one edge in the sketch.
Message 7 of 8
etfrench
A two direction chamfer would be the easiest method.
ETFrench
Message 8 of 8
Didn't know about this flavour of chamfer. I like it!
