All sketches have multiple border lines and I need them to be a single clean line
Jbgumby27
Observer Observer
Jbgumby27
Observer
Observer
I'm trying to create a clean .dxf file for a laser engraver but the double edges are apparently causing issues. I'm new to the program and I've tried a lot of things I've found online but nothing has worked. I get the same result for an imported dxf, a sketch created in Fusion 360 then saved as a dxf, and a sketch created from projecting the surface of an object onto a plane.
laughingcreek
@Jbgumby27 wrote:
..., a sketch created in Fusion 360 then saved as a dxf, and a sketch created from projecting the surface of an object onto a plane.
can you attach this to a post? (from the file menu, export as a .f3d file and attach that)
Jbgumby27
Observer
Observer
here you go
etfrench
The attached was just all bodies projected to a sketch.  Does it work?
ETFrench
Jbgumby27
Observer
Observer
no. it's one of the things I already tried
laughingcreek
Is that a pic of the file when you import his dxf into a new model?  When I do there a no double lines.
attach your model where all you've done is import the dxf.
Jbgumby27
Observer
Observer
The most recent picture is what I get when I downloaded the file etfrench posted and opened it in Fusion 360. No other steps taken.
I'm not sure what you want me to send this time. Could you me more specific?
