All my files are gone?
Message 1 of 13
ummm... Was working this am and when i went to the shop everything was gone.
Directories look to be there but no files.
Currently on high pucker factor...
Replies (12)
Message 2 of 13
Beyondforce
Hi @Anonymous,
Did you check online in the cloud? https://myhub.autodesk360.com
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 13
They are there.
But when I click open in fusion it pukes
Message 4 of 13
Beyondforce
Have you tried to re-install Fusion?
Ben Korez
| YouTube
Message 5 of 13
HughesTooling
Sounds like the same problem in this thread yesterday, no fix was found yet. @innovatenate got a screen gab in this thread.
https://forums.autodesk.com/t5/design-validate-document/update-argggggh/td-p/6820248
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 13
Thanks Mark, Looks like the same thing.
Fantastic. I spent a pot of coffee revising my CAM paths and now have 3 hrs to run my part and make a living.
This plus the "greased pig" chasing of post processors might just make me dust off the windows computer and fire up my last version of Inventor.
Again. Focus on making solid software and spend less time handing out banners on instagram....
Message 7 of 13
HughesTooling
@Anonymous
If you have no linked parts in the design try downloading the design as an f3d from the dashboard then use New Design From File to open in Fusion.
Mark
Mark Hughes
Message 8 of 13
HughesTooling
If you had your post processor on the cloud and it doesn't show up now look in this folder
C:\Users\USER\AppData\Local\Autodesk\Autodesk Fusion 360\LH8SM2YAWZTX
USER will be your user name, LH8SM2YAWZTX will be different on your system.
Just spotted you have a mac so not sure of the path you need.
If you find your post store it in your personal posts folder.
Fusion 360 CAM Personal Posts Folder Locations
_______________________________________________________________________________
Microsoft Windows:
%appdata%\Autodesk\Fusion 360 CAM\Posts
Mac / Apple / OSX:
/Users/<user id>/Autodesk/Fusion 360 CAM/Posts
Mark Hughes
Message 9 of 13
innovatenate
Autodesk Support
Autodesk Support
@HughesTooling Seriously thank you!
@Anonymous Can you share your diagnostic log files with us?
There's a suggestion in the below link rename the .dat file for the data panel. Can you give this a try and let us know if it helps?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Data-Panel-does-not-function-in-Fusion-360.html
I hope that helps! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 10 of 13
re installed saturday and everything was good to go. All files back.
Now today Im getting the error about "Terms have not been agreed" Tried to remove the file per the instructions in other posts (i do not find the path they are pointing me to)
tried to click the error button and fusion does nothing. Spinning beach ball.
This is getting so old
Message 11 of 13
innovatenate
Autodesk Support
Autodesk Support
@Anonymous Thank you for the update and I'm sorry to hear you running into additional issues. It looks like you're running on MacOS. Do you run anti-virus software on the computer by any chance? It would be helpful if to take a look at your diagnostic log files. There's a command in the help menu if you can share them with me.
To resolve the error message, can you try the following steps:
1. Close Fusion 360
2. Browse to the below directory
Windows:
C:\users\***\appdata\local\autodesk
How to access hidden files and folders in Windows
MacOS:
MacHD\Users\***\Library\Application Support\Autodesk
How to access hidden user library folder in MacOS
3. Rename the Web Services folder
4. Restart Fusion 360
I hope this helps!
Nathan Chandler
Message 12 of 13
#3 Rename web services to what?
Message 13 of 13
Hello, Im havinng a break down . i opend fusion and now all my files are gone. i went into the app and under activity it show that all my files folders I  made where deleted!!! HOW DOS THIS HAPPEN!!!!!!!
HELP ASA{
