hello i need this part to be aligne on the axes,it is tilted abit and i want the slots on the parts to be topp.??
i have imported this part
Solved by laughingcreek. Go to Solution.
This can be done with a joint origin or with an auxiliary sketch.
I show it in the screencast.
I assumed that the rear wall should be aligned vertically.
But you can also do it on the slot walls.
günther
since this is an imported part without history, I would use align command to position relative the components origin the way you want, then back the align features in by right clicking and selecting "convert to DM feature"
