Align two meshes of the same part that was scanned from different angles
philippeB6BLN
philippeB6BLN
Hi, I scanned a motor mount, from different two different angles to get as much detail as possible.
Is there a way to import them in fusion and use a function that will align the two meshes ?
etfrench
If you can identify 3 identical points in each scan, then you can use the mesh tools to align them starting with a 3 point plane.  You may also use an axis and a point.  Converting the meshes to breps will make the process easier.
ETFrench
