Align Tool Issues
Align Tool Issues
jleadbetter
Align Tool Issues
jleadbetter
Hello All,
Having a strange issue with the Align tool.  I have attached a few pictures to help demonstrate.
When I start to align bodies, it appears that all is good until I press the OK button.  When OK is pressed, the nut in pictures shifts about 22mm towards the bottom hole.  If I use the hole on the top to align, it will shift down towards the middle hole.  Can't seem to figure this out and would love some help.
Jason
daniel_lyall
Can you post the file Go to File -> Export and save as a .F3D Archive File and attach it to your next post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
TrippyLighting
Looking at the images you posted I'd ventiure a guess that the align tool is likely not not the right tool accomplish wht you want to. As you seem to work with biodies you might also have missed a key ingredient in Fusion 360. That is the difference between bodies and components.
When done reading that, you should be reviewing Fusion 360's R.U.L.E #1
