Align operation not working. Objects moves to wrong position after hitting OK on Align dialog
RogerInHawaii
RogerInHawaii
I'm having difficulty aligning two objects.
I select a line on the object that I want to move.
I select the target line on target object.
And having selected that I see that it has performed the move/alignment exactly as I want it to be.
But then I hit the OK button on the Align dialog and it moves it again to a completely incorrect position.
Why is it doing a subsequent move?
How do I get it to leave it exactly where I specify the target location?
TheCADWhisperer
@RogerInHawaii
If the data is proprietary, you can make up a dummy assembly that exhibits the same behavior.
kacper.suchomski
Hi
Please do not use the Align command. It's an outdated tool from a previous era, when Fusion didn't yet have professional features.
Please use Constraints and Joints.
Kacper Suchomski
pkomatlapalli
Hi @RogerInHawaii ,
Did the information provided by kacper.suchomski  help resolve your issue and answer your question? If so, please click the “Accept Solution” button. This helps other community members more easily find and benefit from the information shared in this thread.
If your question has not yet been fully resolved, please feel free to provide an update in this discussion. This will keep the community informed of your progress and allow members to suggest additional steps or recommendations that may help you achieve your desired outcome.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
