Hi Paul,
While waiting for you response to my clarifications, I came-up with the following workflow to reach my goal, but unfortunatelly the split face or body does not complete.
Here are the steps in the workflow:
1- Project the sketch curves of the plates onto the fin surface.
2- Defined a selection set comprising the sketch curves.
3- Split the Fin surface using the projected curves, this would (theoretically) result in faces equal to the number of curves plus a fin skin that has openings equal to the same number and sizes of the sketch profiles.
4- I would then thicken the fin outwards by 2cm
5- Thicken the new group of faces inwards by 1cm, and maybe move them inwards by 0.5-1 mm to get some tolerance.
6- scale the group of bodies by .1% to give it an overlap with the edges of the Fin openings.
7- then I would go about tackling the sliding joint part.
So, as I mentioned earlier, the split face/body (I tried both) did not complete, I would start the command in patch environment, Select the face, then use the selection set I defined as the splitting tool and it would stop their asking for the splitting tool (although it is populated in the dialogue box).
I'm attaching the file for you to try to replicate what I want to do, you may be able to find out what is wrong here.
BTW, my action steps are on (Components2:1)
BR
Hani
