- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please forgive me, this is probably one of the simpleist tasks, however my mind is still in Inventor Mode (Inventor User trying 360).
In the attached I have (2) parts. I easily made a joint with the 2 LARGE cirlces (green and gray) and set an offset in another joint to have them a certain distance from each other. But now I need to square up using the 2 holes. I should say the gray part was dirived from the green part (inserted and lines projected).
In Inventor I would just simply use a constraint and align via an axis of each hole.
Can someone help?
