Hi.
I have searched and have not found any way to adjust the length of an attribute content. For example, my name will fit easily inside the title block area, but the attribute is breaking the line into two lines.
Does anyone have a tip for this?
Hi.
Solved by ClintBrown3D. Go to Solution.
I would suggest that you delete the attribute and put it back in again.
There is some code that runs in the background that will "squish" the text to fit. The current placement of the attribute might be affecting this, place the new attribute a little further down, so that it is not intersecting with the "Designed By" text. I've noticed that placing a new attribute often fixes and issues.
Hi.
Thanks. I will try this.
Hi.
