- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've migrated some Solidworks and am having a tough time switching over to the Joint system.
I want to add a washer to a threaded stud (see screenshot). There are no nice edges, and later on I want to adjust the length of the stud as well.
How do I do this?
I've tried to do a Slider joint between the washer and stud. But I can't get it to "stop" at the horizontal surface using a planar joint. I get conflicts.
If I do a Rigid joint between the washer at the top of the stud, I can manually slide the washer down. But I would have to eye-ball it so it's just at the horizontal surface. This will "break" once I change the length of the stud.
Any advice would be highly recommended!
