Adding Threads to a sphere
I took a simple sphere and have shelled it then cut it in half. I would like to make one side of the sphere screw into the other. There are a couple of different methods to use and I was wondering what the best would be. Essentially a real life example would be the plastic easter eggs they hide candy in. Thread command does not work for this for some reason.
HughesTooling
You need to create a counter bore on one half and a boss on the other with parallel side like the image below. I used a revolved sketch as it's easier to setup and edit.
Mark
Mark Hughes
Owner, Hughes Tooling
@HughesTooling is that PMI in Fusion?
HughesTooling
No it's not PMI. All I've done is make the sketch visible then enabled show dimensions on the right click menu.
Mark
Mark Hughes
is there anyway you could add a screen cast of the entire process.  I'm missing the a few steps between making an arc sketch offsetting the line and adding the thread?
