Adding deep texture to shape
sofia
Message 1 of 12
sofia
I am going to add a texture keeping the outer measurements of the shapes. I changed the profile and it works fine using the sweep command/loft command but I can't get the ends right. I assume I should try to elongate the centreline (for the ring) and the path+rail (for the U shape) following the half sphere but can't figure out how to. Please see images on where I am stuck and also desired look on ends.
The continues shape (without ends) won't loft even though I have projected intersected points to make sure all curves are touching the profiles. Any advice on this? Image attached.
Many thanks,
Sofia
Replies (11)
Message 2 of 12
TrippyLighting
Aside form the online image viewer function being broken at the moment, it is usually much better to embed images into a post instead of attaching them.
That can easily be active using the large camera button in the menu bar above the text field in the post editing dialogue:
Message 3 of 12
jeff_strater
you might have to do the ends as a series of lofts, rather than a single loft.
However, I would be tempted to do this as a Form/T-Spline body.  It seems pretty well suited to this kind of shape.
Jeff Strater
Engineering Director
Message 4 of 12
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file(s) here?
Message 5 of 12
sofia
Please see embedded images @TrippyLighting Screenshot 2020-01-30 at 11.49.52.pngScreenshot 2020-01-30 at 13.17.04.pngScreenshot 2020-01-30 at 13.17.29.png
Message 6 of 12
sofia
Please ignore the question regarding the closed shape, was just a matter of keep trying and rebuilding the same thing.
So for the u-shape I would think the best would be to have one rail going inside the half sphere and the other on the outside of the half sphere meeting at a point (both being connected to the other rails ) before doing the loft/sweep and similar for the other open shape. But can’t figure out how to make those rails..
All best,
Sofia
Message 7 of 12
TrippyLighting
Beautiful hand sketches!
I think I would model this as a T-Spline and probably also star with the model in Blender. In Blender I would model this as a straight piece and then use a curve modifier to bend it into shape.
Message 8 of 12
sofia
Thank you @TrippyLighting !
These will be updates of the ones I have made that are smooth so therefore it would be nice if I can use the same inputs as much as possible, so they end up as coherent as possible. Is there no way to extend the rails?
Kind Regards,
Sofia
Message 9 of 12
TrippyLighting
Without access to the design there is not much we can do 😉
Message 10 of 12
sofia
I got some help using another CAD program but it would be nice to know for other future designs if there is a straight forward way to do it. I have attached the file for the open ring.
Kind Regards,
Sofia
Message 11 of 12
TrippyLighting
Looks like I totally dropped the ball on this thread.
I did this by tinkering around in Blender for maybe 30-45 minutes.
Imported into FUoisn 360 as a quad mesh, converted to T-Splines and rendered.
Message 12 of 12
sofia
Thank you @TrippyLighting , doesn't seem all that easy but good to know for the future and also how to combine the programs!
