Adding a tolerance to all dimensions in a drawing
rjeAT6XG
Message 1 of 12
rjeAT6XG
Is there a way to place a tolerance on all the dimensions in drawing either automatically before dimensioning or after I've placed my dimensions?
Such as here:
Replies (11)
Message 2 of 12
jhackney1972
Normally this information is either a placed text callout in the drawing or part of the title block.
John Hackney, Retired
Message 3 of 12
Drewpan
In much the same way as threads have been standardised in fusion, the request has been made to the developers
to offer tolerances for fits. Hopefully as more people request this stuff they will consider it.
Right now it is a note in the documentation or you model it exactly.
Cheers
Andrew
Message 4 of 12
ClintBrown3D
Hi @rjeAT6XG
The current workflow is to double-click the dimension once placed, then add a tolerance, we support multiple tolerance types.
Is your question more around setting this up before you place the dimension? So the ability to place multiple dimensions with a +-0.2 tolerance?
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 5 of 12
rjeAT6XG
Yes, either set it up before I start dimensioning or select ten dimensions and add the tolerance to all of them.
Message 6 of 12
ClintBrown3D
Hi @rjeAT6XG
Bear with us. We have a dimension format painter in the works. This allows you to “copy” the tolerance information from one dimension to another (or multiple dimensions).
I'd love to hear from you directly, and to get your thoughts around this. If you're up for it, here is a link to my calendar , please book a 30-minute session with me, and we can chat on Zoom (Note that times are in 24:00 format so 03:00 is 3am, 15:00 is 3pm).
Clint Brown
Message 7 of 12
rjeAT6XG
I booked a time.  Thanks!
A format painter sounds like a great idea.  I hope we see it soon.
Message 8 of 12
johnemartin
Any update on the format painter tool?
Message 9 of 12
rjeAT6XG
It's been deployed for awhile, but it's easy to miss if you don't read all the "what's new" releases.  It's under a right click while dimensioning:
Message 10 of 12
johnemartin
Thank you!
I see it works by using shift to select multiple dimensions, too!
Is the term "format painter" protected? I've seen repeat dimension, but
didn't know what it was.
Message 11 of 12
rjeAT6XG
I don't know how they picked the names.  I think this isn't just a format painter though, as it picks up the tolerancing style at the same time.  Pretty useful though, I wish I'd always had it.
Message 12 of 12
johnemartin
Hi ,
One thing it doesn’t capture is if you have a reference dimension. Still
have to go back and change those one at a time.
J
