Adding a Prusa 3D printer to Meshmixer
Message 1 of 21
I do my design work in Fusion 360 and have been using Cura to create my gcode. Someone recommended I try Meshmixer. The list of pre-installed printer parameters there is pretty small & I can't find any guidance on setting one up from scratch. Has anyone set up a Prusa i3 MK2S? any particular issues?
Accepted solutions (3)
Replies (20)
Message 21 of 21
werner_kaffl
The problem is, printers.xml is marked "readonly" in Windows. At least that was my default on Windows 11.
Solution:
Locate the printers.xml file in your Documents\meshmixer\printers folder, right click the file, click preferences and untick the readonly box. Then apply and close. Now all printer changes will be updated permanently as it's supposed to be.
That's not necessarily a Meshmixer bug, more likely an issue with Windows permissions supplied during the install process. A lot of this has changed since Meshmaker was last maintained.
