Adding a Flat Pattern View to Drawing?
jdmwrxpower
jdmwrxpower
    In the drawing workspace I am trying to figure out how to add a sheet metal flat pattern bending view to my sheet. I did create a flat pattern in the design workspace. When I run the automatic drawing creation it adds it but I am trying to do the same in my custom drawing I started from scratch. I can't seem to figure out how the automatic drawing was able to make it.
jhackney1972
The attached video will help you create your sheet metal drawing using the flat pattern.
John Hackney, Retired
jdmwrxpower
Thank you John. I was able to select the drawing I'm currently working on to add as a sheet. Perfect!
