Adding a border to a surface
trskel
trskel
Hi all,
I am modeling this helmet:
As you can see, there is a raised border all around the limits of the surface, and around the limits of the nose guard.
Is there any easy way to do it in Fusion 360?
Thanks in advance.
TheCADWhisperer
Split and PressPull
or
Sweep
or
Split, Offset surface and Thicken
or
Offset surface, Trim and then Thicken.
File>Export and then Attach your *.f3d file if you can't figure it out.
trskel
Hi, Thanks a lot for your suggestions.
Still cannot figure it out. I attached the file, can you show me how you would do it in this case?
Thanks!
TrippyLighting
For something quick you could just use the pipe tool:
trskel
Yes it works great. Thanks!
