Add a "mirror" option to the Emboss tool
infoTF5PA
infoTF5PA
When embossing text on the "top" and "bottom" of a body, the user is required to make two different sketches in order to emboss as desired.
If there were a checkbox to allow a mirror of the emboss sketch on the emboss tool dialog, the user would be able to use one sketch to emboss the "top" and "bottom" of a body.
This could also be implemented with an invert checkbox on the mirror tool.
davebYYPCU
You Mirror text, and can still read it?
For Text at least, I would use Circular Pattern > Feature would more likely result in text you can read.
Might help...
infoTF5PA
Thanks! Seems like a nice work around.  I will give that a try.
