I downloaded a 3d sculture but the base is not flat. I would like to add a body ( a new base) or fix it.
Please help. Thanks
If you haven't already, make the sculpture a solid by doing a mesh repair to make it watertight then convert to
solid. Then create a sketch and project the old base to get the shape outline and extrude it. Extruding it down a bit
should make it flat.
Cheers
Andrew
Saint Joseph is said to be the patron saint of craftsmen, engineers and Fusion users among others so perhaps he can help? I have managed to close the holes and am working on some other issues. Will you 3D print?
Converting a mesh with that many faces into a solid is a B.A.D idea.
That is particularly the case when trying to perform a solid modeling operation on it!
