Accidently closed open recovery file dialog solution.
Doriantgt
Doriantgt
If fusion crashed and you re-open fusion it should open a dialog box to re-open your files as you had them. You may click the close button because you're tired and working late and usually, that is where the OK button is on a dialog box. But, lets say like me you hit close, well if you quit and re-open fusion it will not prompt you with the recover file box again. The solution is the ctrl+alt+delete or cmd+esc and force quit/end task fusion. This will cause fusion to think it crashed again re-prompting you with the dialog box so you can right click->open file the files you had.
rohit.bapat
Hello @Doriantgt
Can you please check if solution shown in this post https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t... helps? Do you see this option in the menu?
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
jeff_strater
if there are any recovered documents, this command will re-open  the recovered designs dialog:
Jeff Strater
Engineering Director
