Ac Core Console
Ac Core Console
design1JMDX8
Message 1 of 8
Ac Core Console
design1JMDX8
Hi everyone.
I'm having major troubles with creating drawings with Fusion.
The program would freeze and guaranteed to crash and close, it's becoming a very labors task to create drawings and a lot of time wasted.
With my task manager open and Fusion still frozen AcCoreConsole is cleaning out my computers overall performance.
Any suggestions?
Replies (7)
Message 2 of 8
TheCADWhisperer
@design1JMDX8
Is this relative to a specific file geometry, or if you create a new file with only a cube do you observe the same behavior in the new file?
Is this a new issue (used to work fine for you on this machine) or did it never work for you?
Can you File>Export a *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Message 3 of 8
LishuangLu
Hi @design1JMDX8 , thanks for reporting!
To help us better understand and triage the problems, could you please provide us more info and follow below instructions to report?
  1. Please share your Fusion Diagnostics Log which can be extracted from Help->Support and Diagnostics->Diagnostic Log Files.
  2. For the drawing performance issues please submit a report through "Report Performance Issue" found under Help -> Support and Diagnostics.
  3. If the workflow finally crashes in your end, please also submit crash report with your email address and detailed description filled in.
Thanks for your support!
Lisa
Message 4 of 8
liang_chen
HI@design1JMDX8 ,
May I know which OS are you using, and the details of the OS ? Please try to updae the drive of graphics card and VC resdist, as well as other pending OS update. The restart OS and check if it will work. Thanks
https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170#visual-studio...
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Message 5 of 8
design1JMDX8
Thanks Lisa.
I'll give this a try and let you know
Message 6 of 8
design1JMDX8
thanks Lisa.
I'll give this a try and I'll let you know
Message 7 of 8
design1JMDX8
Hi Fred.
All my drivers are up to date. it was the first thing checked.
Message 8 of 8
liang_chen
Please also check if it works after installing the latest version of Microsoft VC redist.  Thanks
Fred Chen
SQA Engineer
Autodesk, Inc.
