A360 is down, Fusion 360 won't allow a local export...
mcramblet
Message 1 of 9
mcramblet
I realize that A360 is currently having issues. I don't know if this is a known issue or not, but I can't export a version of my open file to a local back-up, when it's down. I get the message below, which doesn't seem like a good thing if someone want's to export a file to a backup or to continue working with the file elsewhere. Is there any way around this?
Replies (8)
Message 2 of 9
mcramblet
I went off-line, re-opened the file and tried to export it, with same result as before.
Message 3 of 9
mcramblet
Nor does restarting Fusion help this issue. I'm still off-line, opened the file, but get the same message if I try to export.
Message 4 of 9
brianrepp
Hey @mcramblet - thanks for reporting, and unfortunately this looks like a regression.  This used to be an issue, but had been fixed.  I've escalated and we will fix this issue ASAP.  In the meantime, there unfortunately isn't a workaround Smiley Sad
Message 5 of 9
brianrepp
@mcramblet - you should be coming back online now, please let me know if you continue to have any issues.
Message 6 of 9
I_Forge_KC
@brianrepp
There is a user in the FB group reporting the same behavior.
K. Cornett
Generative Design Consultant / Trainer
Message 7 of 9
brianrepp
@I_Forge_KC - thx for confirming, and yes, we also reproduced internally.
Message 8 of 9
mcramblet
@brianrepp-
Yes, I'm back online and as soon as I was, I was able to export as usual.
Message 9 of 9
mcramblet
Although I could export once A360 came back online, I guess I should keep this open until the regression is resolved.
