Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
A way to make 1 nut push two bolts in opposite directions
5 REPLIES 5
toffypops
360 Views, 5 Replies
I am trying to make a gadget where i have two bolts going into 1 big nut. I want the nut to SEPARATE the bolts in separate directions, and close the gap reversing it. How can i achieve this? Soon no more hair left...PM me on Face 😛
5 REPLIES 5
jhackney1972
in reply to: toffypops
I notice that the barrels on both sides are threaded.  The answer is a long nut with RH threads on one end and LH threads on the other with matching threads on the barrels.  This is how a turnbuckle works is everyday life.  Turn it one way it tightens, whatever is hooked to the ends and the other way it loosens.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
g-andresen
try this way
günther
jscott6SWZG
davebYYPCU
in reply to: g-andresen
Surprised you didn’t Mirror join the first body.
toffypops
Ended up with this based on feedback above. from my understanding it should work. 🙂
Thnx for the answers all.
Technology Administrators
