A way to create the last Component in a Drawing again without going to Plan?
- Mute
- Permalink
- Report
When creating a Drawing in the same sheet I am constantly going back to the reference Plan to do Right click on Component -> Create Drawing -> Drawing pop-up -> Select existing Drawing -> Select existing sheet -> Ok
This is about 5 to 9 clicks for each view of a component I need to put down in a Sheet. Depending on if a new sheet is needed, whether the popup window registers the correct clicks, etc.
If I have to do, say 20 components, each with 3 to 4 views it gets repetitive, error prone, and time intensive, etc.
With a large history chain, Fusion bogs down toggling between Plan and Drawing tabs each time and can take 2+ minutes just to render the Left side Navigation tree each time. (i7 quad core, 16 GB RAM, Nvidia 960, gaming laptop)
Combine the number of clicks with the repetition and the time delay and drawing creation is a major chore that can easily take over 5 hours.
Is there a way to save the last component to some kind of Clipboard and then stay within a Drawing sheet, and just select that component from a list or use a hotkey somehow to just paste / create the most recent component again into a sheet?
Rather than doing all the steps to select a component from the original plan each time for each view?
I'm going to feel really stupid if you tell me I've been adding Components to Drawings the hard / wrong way and there's a much easier / faster way.
Thanks.
