A strange sketch problem
lemelman
lemelman
I'm drawing a simple sketch and need to divide a closed area into two separate closed areas.
There are two such areas, one divides OK, but the other one doesn't. Why?
I've attached a screenshot of the sketch, a video that that shows the error, and the .f3d.
jhackney1972
Please add the F3D file.
John Hackney, Retired
lemelman
Sorry, I thought I'd attached the .f3d. Here's another attempt.
g-andresen
In sketch 4, an arc is missing.
Add missing arc via "projection"
günther
lemelman
Hi Gunther,
Thank you for your reply, which works fine. I still don't understand why the whole section is considered to be closed before the right hand arc is drawn, but then then deemed 'open' when the arc is drawn. Somewhat inconsistent, me thinks.
g-andresen
Closed profiles can only be created by lines within the same sketch.
To detect open profiles, it is helpful to deactivate previously created sketches step by step.
This allows you to see whether, for example, lines have been “lost” in the projection.
günther
