Hi!
Is there a way to perform something like this?
The shown picture is made by Rhino. I can draw a 3D path and then draw the circle...
Thank you
L.
Hi Lucio,
You almost have it, if the circle is on a sketch plane on the end of the sweep all you need to do is use the sweep command select the circle first then the path is the 3D sketch. The key is to have the circle sketch on the end of the path.
Hi, yes there is a fairly easy way to do 3D sketching like that, please refer to this thread:
Let us know if you have any other questions!
Jesse
