3D Sketch to Flat Pattern.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am looking for advise or work flow to go from a 3d sketch to a flat pattern .
I am going to use 26 ga galvanized material so it about .021 in thickness.
I have read through a few post on this site and checked out the couple available you tube videos but i find it does do not give me the flat pattern sometimes , most of the time.
I am trying to come up with flow so I can build any crazy transition in 3d sketch and make it flat.
I have and still use sketch up 8 pro with the "flattery" add on which work decently and will convert just faces to a flat pattern.
but, I trying to covert all my work flow to stay within the fusion 360 ecosystem.
is there a way do convert surfaces / face to a flat pattern in fusion without thickening the face to a body? as if I was using a material like paper?
thank you
