3D printing utility
3D printing utility
joe
Message 1 of 1
3D printing utility
joe
When using 3Dprint utility to send the stl directly to Kisslicer, it is sent as a (ad648462-adf7-41d3-9d1a-2136a59983a7.bfb) file. after slicing before saving  to usb drive I rename the file. While saving Kisslicer runs the file thru a utility that converts the file to be printed by a 3D systems CubeX printer. That "Cubeitmod" utility fails to convert the file when you send it directly to the slicer from Fusion. If I save the model as a stl then load it to Kisslicer everything works fine.
Is anybody using Kisslicer and Cubeitmod?
Replies (0)
