3D Print units
3D Print units
joe
3D Print units
joe
Is there a way of setting the units  to inches when I export from 3D print to an STL file? As of now it exports in MM
Phil.E
What units is Fusion 360 using when you do the export?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
joe
My part is designed in inches, fusion exports in mm and there is not an option to change this. I then open the STL in my slicer and I have to convert to inches. My other CAD gave the option before the export
bob_holland
Autodesk Support
Autodesk Support
@joe,
Joe I have replicated your issue and have logged it with our development staff.
Issue ID:  FUS-23955
As a workaround you can send it to Print Studio and then save it a STL.
Bob Holland
Autodesk Product Support
joe
Thanks Bob, Where can I get a copy on Print Studio?
bob_holland
Autodesk Support
Autodesk Support
@joe,
When you go to the 3D Print option:
Fusion will provide you with the ability to download it:
Please let me know if you see something different.
Bob Holland
