3D Connection space navigator - zooming and initialisation
- Mute
- Permalink
- Report
I have a space navigator that is exhibiting two separate issues
1. when I start F360 after my computer starts up, more often than not I have to unplug and replug the navigator to get F360 to work with the navigator. It seems to work 2nd and later f360 startups.
2. Navigation often becomes very sluggish after manipulating anything more complex than a cube. It feels like a buffer has filled up, and swamps the real-time incoming control messages. More often than not, I zoom out when it gets sluggish (it takes a while to get the image to move) - once it is zoomed out, navigation response goes back to the expected level, but usually doesn't last long before it gets sluggish again.
Any thoughts or suggestions? Let me know if you need any more details
Regards
Peter
I have two side by side displays:
Main display:
[GPU Information]
GPU Device: NVIDIA GeForce GTX 1070
GPU RAM: 8192 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 1.4.501
GPU Driver Date: 09/01/2016
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Display
[Limit effects to optimize performance]
Off
secondary display:
Intel(R) HD Graphics 530
Report Date: Monday, February 13, 2017
Report Time [hh:mm:ss]: 10:36:34 PM
Operating System: Windows* 10 Home (10.0.14393)
Default Language: English (United States)
Physical Memory: 32611 MB
Video BIOS: 1033.0
Processor: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Processor Speed: 4008 MHz
Processor Graphics in Use: Intel(R) HD Graphics 530
Shader Version: 5.1
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display *
Display Type: Digital
Serial Number: 11237JA021005
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Monitor
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 10.63 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1024 x 768 (75p Hz)
1280 x 1024 (75p Hz)
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
