Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
360 Ultimate, create Drawing not working
JonSchaeffer
Message 1 of 8
JonSchaeffer
I'm using this new Ultimate and created a special project for work and the boss tells me he needs prints.
when I go to create a drawing the usual window that gives my my model to place and size it never happens.
I am stuck with no option to make prints.
Need fast help please...
-Jon
www.genesisprecisionaz.com
[email protected]
Replies (7)
Message 2 of 8
TimeraAutodesk
@JonSchaeffer Thanks for reaching out to let us know about this. When you select "New Drawing from Design", is Fusion 360 opening up the additional Drawings tab for you, is it crashing, or is the option to select "New Drawing from Design" greyed out? If you could send over a screenshot or add me to your project so I can take a look at what's going on that would be great.
Timera ([email protected])
Message 3 of 8
JonSchaeffer
not crashing just I just get this little message.
That says Yellow Caution exclamation point    "Unknown command "B"
[email protected]
Message 4 of 8
cmiller66
Hi Jon,
Can you please invite me to your project?  Christopher dot miller at autodesk dot com.  I would like to take a look.
Is this a recent problem with the new update?  it looks like this is a brand new/unsaved drawing - when the new drawing started did you see a preview of the view moving with the cursor?  Did you start the new drawing from the File drop-down menu > New Drawing from Design or another access point like the Data Panel or Browser right-click menu?
Can you try this and see if it works:
1.  Close/drawing (don't save)
2.  Close design/Close Fusion
3.  Re-launch > Re-open design
4.  File > New Drawing from Design
Chris
Message 5 of 8
JonSchaeffer
ok I invited you
Christopher
[email protected]
Message 6 of 8
JonSchaeffer
Yes recent problem is after the update.
I got no preview of the part moving with the cursor.
And I tried both places to create a drawing . I also tried a full assembly drawing and just an isolated component or body drawing.
Every time I get that screen shot and that is it.
[email protected]
Message 7 of 8
cmiller66
Hi Jon,
If both view previews and drawing view creation were working before, it sounds like your update had an issue.  it might be easier to take the debugging of this offline, if you can email me at the same address, christopher dot miller at autodesk dot com we can dig into this a little more deeply and hopefully get you back up and running ASAP.
Chris
Message 8 of 8
JonSchaeffer
After a few times going in and following your steps for a clean uninstall then a re install I had problems.
But after rebooting at my work location things seem to be working great...
[email protected]
