30 Degree Chamfer on Hex Nut
Learning Fusion 360 as I go; pretty rough so far.  I can construct and extrude a hex nut just fine, but I'm having trouble finding a simple way to chamfer the corners to a 30 degree angle (from the points to the inscribed diameter).  It seems relatively straightforward for a 45 degree angle, but I need a 30 for some applications.  I would like to figure out how to do it vs. downloading a McMaster Carr model.
TheCADWhisperer
Extrude-Intersect with Taper a circle.
So easy once you know this trick!
