I really don't know if I'm asking this in the right section, I apologize if it is in the wrong place. Basically I'm trying to keep my balloons in order. I have one of my first pages containing a table and balloons pointing to the components on the full assembly. Thinking that on every drawing I later create of those individual components that I can label them with a balloon so the fabricator can locate that part in the assembly drawing. That isn't working, every new drawing of a new component gives me the item number of 1, but in the assembly the item number happens to be 2. It does it with any component, ones that should be 6 or 7 still show as 1. Which honestly is useless. Surely it shouldn't be this hard to show where a part is in it's assembly? Please help if possible, thank you
Solved by jhackney1972. Go to Solution.
I hope I am understanding your question. If I am, the video will give you the solution.
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you would like to read more about why Accept Solutions are important, take a look at this webpage.
John Hackney, Retired
Thank you! That problem has been driving me crazy, I really appreciate the help. That should work for the majority of the issues I've been having with the balloons.
