- Mute
- Permalink
- Report
Hello everyone i am still quite an NEWB but i have a design question. I have created some sink basins we manufacture in FUSION 360. I need to use this Sink basin in a 2 d drawing that shows the sink basin dimensions As well a nice picture of the sink style. So using Drawing by design i have created a standard layout view of what i wanted. However there are multiple sinks of each style we manufacture. I export the layout with per attached Image as a PDF. I open in Acrobat Pro. I have to remove the dimensions an replace with table references A B C D E F excetera for my final layout within Adobe Indesign. Once the dimensions have been replaced . I do a crop around the target image to exclude the rest of the page you have to EXPORT from fusion. Then i save as a PNG. What i am running into is the quality of the image has reduced in my opinion please see image for reference. I am hoping there is a much shorter path out there to what i am trying to achieve here. Is there some way to convert these images from fusion to other formats then just DXF PDF DWG. Any help would be better than the help i am getting from ADOBE on this matter would be greatly appreciated. Also it would be great if i Could substitute the dimensions for other alphanumeric symbols to be used in TABLES for Literature instead of having to re edit everything in another program. REMOVE dims and sub with letters for table
final lay out image is still rough
How i export from fusion
