2D Drawing - Dimension not showing
winch_siwawong
Message 1 of 11
winch_siwawong
Does anyone know why dimension is not showing and how it fix it?
Replies (10)
Message 2 of 11
TimelesslyTiredYouth
Hi @winch_siwawong
Right, you need to clarify whether dimensions are not showing when you're in sketch mode or not.
I'm presuming their not showing when your off sketch mode, and you want them to display at all times, to do this, find the sketch in the "tree" browser, right click mouse or touch pad, scroll down and you'll se the option to "show sketch dimensions" This will allow you to see dimensions when not actively in sketch mode, will provide further details once Fusion has loaded
If I have misunderstood, please don't hesitate to ask further question
Sleepy Regard
Ricky
Message 3 of 11
bwalker145
@TimelesslyTiredYouth: This looks to be the Drawing environment, not sketch.
@winch_siwawong: Is this the only document/sheet that you see the issue with? Or are you experiencing this with other files as well?
Message 4 of 11
@bwalker145 Thank you for the insight but I couldn't be entirely sure as the OP wasn't the clearest unfortunately.
@winch_siwawong Can you share the file if it's okay so we can see if this issue is reproducable or if it's on your end please.
Message 5 of 11
jhackney1972
This is probably due to a video problem.  I would try and change my video driver in the Fusion Preferences and also see if your video drivers are up-to-date.
John Hackney, Retired
Message 6 of 11
winch_siwawong
Thanks for the answer. I already check DirectX version for my labtop is ver.12 is that will be the cause?
Message 7 of 11
winch_siwawong
All of entire document😓
Message 8 of 11
All of entire document, just this or all of yours. Can you share this file, or share a quick replica file with the issue if it's across all files via:
File -> export  -> F3d -> drag and drop here.
So we can see the porblem closer and see if it's reproducable on our ends
Message 9 of 11
winch_siwawong
Message 10 of 11
HughesTooling
@winch_siwawong Take a look at this page, near the bottom it shows how to set up a windows environment variable so you can set different drivers just for the drawings workspace. If gives you five options including software or hardware drivers.
Mark Hughes
Owner, Hughes Tooling
Message 11 of 11
johnsonshiue
Hi! Another possibility could be the font associated with the drawing is corrupted. You may want to uninstall and reinstall the font.
Many thanks!
Software Test Engineer
