2 User Interface Bugs - Render
1 ) It is not possible to edit the settings in the Render settings. You can simply not reach them. Mouse wheel don't work, windows is not scalable and that is not a slider...
2 ) And if you close the render settings window there's no way to open the window again, without deleting everything
donsmac
You can resize the window. Click and drag the lower right corner.
I agree there ought to be a way to pause the render if the Render/ Ray Trace window is closed.
Maybe it isn't a "real" Bug
But then it is very user unfriendly. You can not scale the window if its in the doc position, you have to undoc it and scale the window, and re docking it again...
I really don't think it can be expected at useres should be able to guess that, I personally didn't Smiley Sad
TrippyLighting
I aagree. The render UI generally is not on par with the rest of Fusin 360 and I find it clunky. I've noticed this same behavior and IIRC on my Mac I was not able to resize that window, but I have not checked in a couple of updates whether that behavior has changed.
If you have trouble with scaling the window,  you have to first undoc it and in the corner where the close button is drag ( and yeah there is no marking the telling you as possible to dragging this corner...)  then doc it again  and restart fusion 360  to save the new window settings.
I think it's a "real" bug ! That the shipping settings don't give you access to that controls, and the interface dont tell where its is possible to drag the window and why Isn't it possible to drag it in the opposite corner ? it will make a lot more sense.
