2 issues
2 issues
Message 1 of 13
2 issues
I am having 2 issues , first one is that when I highlight a group of bodies and try to move them  some of them un highlight when  clicking move button  , this also happens when I have bodies from 2 component groups some of   the groups will unhighlight.
also I  am not able to find any documentation on how to  change the order of  the  components ,  and bodies
thanks
Replies (12)
Message 2 of 13
O.Tan
Please display us your Browser Tree so we'll be able to assist you better as one of the few possibilities on why some of them unhighlight could be cause it's grounded and probably you highlighted a mixture of components and bodies
bodies live in a component, you can only change the order of bodies within a component and changed the order of components. How you do this is simply, left click + hold on the component or body in the browser tree and drag it to the position you want.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Message 3 of 13
not sure how to display my browser
yes I do have the bodies in the components and if i try to highlight 2 compnents either by either  by dragging around them or by right clicking their component boxes in the browser , when I right click and select move some of the parts un highlight.
also on a mac with a smart mouse the left click and drag does not move the components to a different place, I can how ever use that technique to move bodies into components.
Message 4 of 13
O.Tan
Give us this is enough (CMD + SHIFT + 4)
Omar Tan
Malaysia
Message 5 of 13
3 screen shots in order  #1 show before highlighting with click and drag #2 shows highlighting of 4th and 5th axis as named in browser # 3 shows some parts un highlighted
Message 6 of 13
O.Tan
Okay, so now when you refer to:
Problem 1: highlight a group of bodies and try to move them
Which group of bodies are you referring to based on the photo you gave
Problem 2: change the order of the components , and bodies
You can change the order of components within components only, meaning from ur browser tree, you can reorder anything from below Construction but you can't drag it to be above Bodies (or those folder icons) (got it?)
Also assuming you have a few body in bodies, you can rearrange within it or hold + drag it into a component to make it into an assembly.
Btw, I've made a screencast for you (no audio), so try to follow along and lemme know how it goes:
https://screencast.autodesk.com/main/details/510a7c4a-edc1-43c2-a0aa-05562f6726f3
Omar Tan
Malaysia
Message 7 of 13
thanks for the video , this is exactly what I am trying to do , left click drag compnent to new location wait for line to show for new location then release , but my component does not change position.
first issue , I am trying to move everything thing that is on the screen  as per #2 picture and you can see that in #3 picture some thing were deselected when a selected the move button
the parts I am trying to move are the components 5th axis assemblies and also 4th axis assemblies
Message 8 of 13
I just tried to do the above problems in a new file  and both work , is it possible that something is set wrong in the file  that would cause both of these problems
Message 9 of 13
O.Tan
Hmm, not too sure. Can you expand all your browser tree and post a photo of it again? My guess is some of the component is grounded but I'm not too sure.
And next time, you can attach images directly from here:
click on it and this will appear, usually you want it to be either full-size or large.
Omar Tan
Malaysia
Message 10 of 13
added you as a friend I assume that means you can look at my files ? or do I need to do something else?
GREGORE'
THE ART OF JEWELLERY
17 AGTA Spectrum Awards
Mort Abelson "New designer of the year"
AJDC "New Talent Winner"
3 MJSA awards
805-453-6073
www. gregorejoailliers.com
Message 11 of 13
O.Tan
Just received your invite, checking your file now. I'll get back to you
Edit: Okay, so I think I know what's going on now but before I make a screencast, can you confirm this is what you want?
1. When move 5th axis assembly and 4th axis assemblies, it resorts back to its original position, not the newly position
2. You can't reorder the components in browser tree like what I did in the video (place the 4th axis assemblies right under 5th axis assemblies)
Omar Tan
Malaysia
Message 12 of 13
still seems to be the same to me
GREGORE'
3 MJSA awards
805-453-6073
Message 13 of 13
O.Tan
Ah, I was waiting for your reply before I made the screencast but seems that's what I mentioned is what you want, I've made the changes and you can view how I did it from the link below:
http://autode.sk/1JOZkRr
Omar Tan
Malaysia
