2.5D drawings
- Mute
- Permalink
- Report
this is a bit abstract 😄 I want to design a 2.5D keychain of a certain building. Printing the whole building would be to expensive to I thought I would flatten it on one axis.
What I did is a bit work intensive so I wonder if you have some ideas how to make it faster.
You take a perspective drawing like the one I attached and sketch it on the front facing plane. Then you choose how much of the 3rd dimension you want and sketch it out on the ground plane. You extrude the ground plane sketch upwards and intersect the front facing plane and use a taper angle on the latter extrusion to achieve a perspective looks. (see file attached)
I wonder if there a method work you take a full 3d model, force perspective on it and just scale one axis down. Im happy about any ideas that could automate of fasten this process.
Cheers
